Is there a way to set up a tile to turn on a light, but to a settable brightness instead of having to adjust it with a slider? This would allow a LOW, MED or HIGH type of tile setup for certain lights.
As in 4 different tiles - one for OFF, LOW, MED, HIGH?
If so, you could do this by creating a rule for each level you like and adding that to your dashboard.
Hey… thanks a lot. That worked out great. I thought of this, but thought you had to set a trigger. Didn’t know you could skip that part. All this time I haven’t wrote any rules due to trying to keep everything under one place… ie… in Smartthings only.
