Is it possible to have a tile trigger a virtual switch?
Yes. Just make sure you’ve authorized SharpTools to have access to the Virtual Switch. ![]()
- Open your SharpTools.io User Page
- Tap Manage Connections
- Select your desired platform
- Follow the prompts, making sure to check the box for your Virtual Switch
Thanks, forgot that I did that when I set up sharp tools Originally.
