Temperature and humidity missing
I have a door sensor that can also measure temperature and humidity. When I insert it into one of my panels I can only see the door switch. I cannot select temperature and humidity - the two sensors do not exist. The funny thing is that if I make a Super Tiles I can choose contact but also temperature and humidity.
What have I overlooked?
William
When you insert a ‘Thing’ into your dashboard, it uses a default Tile Layout for that device based on the capabilities it has.
You can change the tile layout as noted here:
This could also be a good use case for the new Hero Attrubute tiles with three attributes. My gut reaction is door primary, temp / humidity secondary and tertiary?
Understood - thank you
