Is it possible to get all TAustins Roku Driver Command’s to show in SharpTools
Hi @Paul_Paul - thanks for sharing the screenshots. SharpTools automatically exposes all of the commands that the device defines.
I would suggest asking TAustin how those various keys are sent. Based on the menu saying ‘Select a keypress’ and there being a command called selectKey(), I suspect you have to send the appropriate key code using that command.
Thanks, SelectKey did it, I didn’t even notice it until you pointed it out
