Tasker Plugins Ending
When I opened my Tasker Plugins app, I see that it’s being removed from the Playstore because Samsung is retiring Groovy in September. Are they really shutting it down then? I was thinking about moving many of my Tasker profiles to sharptools.io anyway because my phone died a while back and I didn’t have one right away so profiles were not getting executed but they probably would have if they were on SharpTools.io. I control my garage door based on phone location and Life360. Is something like this able to run on SharpTools? I suspect so but I might have to set up some Edge driver based virtual switches. What a mess. Like I have time to reprogram my life. :stuck_out_tongue_winking_eye:. Thanks.
I suppose time will tell if they actually hit that date, but Mark Benson, Head of SmartThings US, mentioned it on the latest IoT Podcast with Stacey Higginbotham around the 40:00 mark.
As you alluded to, we’ve already made our next-generation SharpTools​.io integration with SmartThings live for new users (which takes us off Groovy). You can find some details on the SmartThings Groovy Update post.
If there’s a relevant device in SmartThings, yes, you can leverage those devices in SharpTools.io rules.
Or if you have some bespoke profiles that are unique to Tasker, you can also have Tasker trigger SharpTools rules using Rule HTTP Triggers. This is a pretty powerful feature as you can continue to use your Tasker profiles and update them to call to a Rule HTTP Trigger (and even pass in parameters). From there, you can either store things in SharpTools Variables or connect those rules up to Virtual Devices.
I can sympathize with that! And it’s part of the reason I wanted to get the message out and pull the app listing. I know it’s not a ton of time, but it’s the first public mention by SmartThings officials and I wanted people to be able to get ahead of this before Groovy dies!
Thanks for the update. And I’ve been using your plugins from the beginning! I knew Groovy was going away eventually but hadn’t seen a date. I haven’t even seen anything on the SmartThings community. I think I tried HTTP requests once before, but didn’t quite get the hang of it. I guess I’ll have to look at it in more detail. I have to move routines out of the Groovy SmartLighting app as well to either SmartThings routines or SharpTools. And my old phone got wet so I just had to waste time rooting and reconfiguring a new Pixel 6. Luckily, I enjoy this stuff (as ideas are popping in my head how to reconfigure my garage door routine with virtual switches and SharpTools). Ha.
By the way, if my SharpTools rules interact with my SmartThings devices because I subscribed to them through the Tasker Plugins app on my phone, will the rules still work after Groovy dies? If not, how do I subscribe to my devices after Groovy dies? I’m getting confused. Thanks.
SharpTools.io automatically takes care of and manages its own event subscriptions. You don’t have to worry about manually subscribing to things as the platform takes care of it for you. :slight_smile:
We’ve already pushed the next-gen connection live for new SharpTools users. It looks like you have a legacy connection on your SharpTools account, but if you’re just getting started, you might consider just using the next-gen connection directly. I just added you to the beta group so you can view details on the beta thread for existing user.
We also plan on introducing migration tools for existing users to migrate dashboards and rules which have legacy devices over to the next-gen connection. :slight_smile:
Q: How do I know if I’m using the legacy or next-gen connection?
On your SharpTools User Page , the legacy connection uses the ‘circle’ icon from the classic app. The next-gen connection uses the 5 spoke icon from the Samsung app.
Additionally, you can tap the ... next to a location to view the location details and the Platform would be reported as samsung-smartthings for the next-gen connection.
Great. Thanks. Does the next gen connection break anything right away with Tasker tasks that use the Tasker Plugin now?
LATER: Nevermind. I think this is answered on the beta page.
Maby i should be added to the beta aswell to start moving stuff :slight_smile:
@josh With the SharpTools tasker app is going away. Would you be able to help explain it and possibly supply some example of how to use the http action an the API calls to help us that depends on SharpTools to interact with tasker and SmartThings.
Control Devices
If you want to use SharpTools.io Rule HTTP Triggers to control devices in SmartThings, here’s a brief summary.
  1. Create a rule in SharpTools and add an HTTP Trigger (Event → HTTP).
    Note: You can optionally define a parameter here if you want to send data/variables from Tasker.
  2. Add desired conditions/actions to your Rule Flow
    Note: You can use the parameters that were passed in from Tasker (defined in the first step) by tapping the </> button next to a parameter, then when prompted to select a variable, tap the Context Variables tab → Event → HTTP Event → Parameters
  3. Copy the HTTP trigger URL to your clipboard and save the rule
    You can tap the copy icon in the HTTP trigger to copy it to your clipboard. You can always visit SharpTools.io from your phone and reopen the rule to more easily copy the HTTP Trigger URL. :slight_smile:
  4. Update your Tasker Task to use an HTTP Request which calls the HTTP Trigger URL
    You can find the action in Tasker under Net → HTTP Request. The default ‘GET’ method is fine, so all we need to do is fill in out URL and optionally add our Query Parameters.
    Note that the Query Parameters field in tasker is in the form parameter:value where parameter is the name of the parameter to send to the HTTP Trigger.
I’ve kept this example intentionally simple, but of course you can take advantage of the full suite of features in the SharpTools Rule Engine once you’ve triggered an HTTP task. Some examples:
  • Pass in a device identifier as a parameter and then use conditions to determine which device to send actions to.
  • Use conditions to determine what type of action to take within the rule (eg. if the value is above a threshold, turn the humidifier on, otherwise send a notification)
  • Store values into SharpTools variables for display in dashboards or as triggers/conditions in other rules. For example, you might compare a passed in parameter or variable against a device’s state within your rule before determining what action to take.
  • Use notifications with Email, Pushbullet, Pushover, SMS and more.
  • Interact with SmartThings and other platforms like Hubitat or Home Assistant
  • Run SmartThings Scenes with our next gen integration
  • And more! Let me know if you have specific questions!
Push Events to Phone
You can also use the SharpTools.io Rule Engine to send push events to your phone (using Pushbullet, Pushover, or Tasker Plugins like Join) and react to those in your Tasker profiles.
  1. Create a Rule in SharpTools that triggers based on whatever device changes you are interested in
  2. In the Flow, use your desired push service to push the message to your device
    For example, you could use Action → Notification → Pushover
    In my example, I’m using Context Variables to get the name of the device for the Title of the message and the value of the triggering device to pass to Tasker.
    Pushover has some nice features where you can access the value of the title / message through %pushovertitle and %pushovermessage variables in Tasker.
  3. In Tasker, create a profile using your desired push service’s plugin
    From here, you can setup your Tasker profiles however you like. Using the Pushover example from above, we have access to the device name in the %pushovertitle variable and the device value in the %pushovermessage variable. You could of course change what data you include in the title and message and adapt to your use case as needed.
@josh You sir are amazing! This is just one of the reasons I love this platform!
We need a premium subscription for HTTP, right? Or can we try them out cuz we are the beta test? I think I’m going to have to get a premium subscription at some point for HTTP, anyway, so I might just go ahead and plunge right in. I haven’t done before because I don’t really use the dashboards much. Instead, I just use the rules. Thanks.
Yes. The HTTP Triggers and Actions as well as Variables are part of premium. We can reset your trial if you’d like - just send a note to support@sharptools.io and we’ll get you taken care of.
You could also use the SmartThings REST API directly with a Personal Access Token if you just want to control devices.
Thanks for the offer, but no worries. Also, with respect to SmartThings REST API, I am at a complete loss with all the API stuff. I looked at the Rules API and couldn’t even figure out how to get started. It’s going to be hard enough for me to figure out how to send HTTP requests to SharpTools so I’ll get a subscription and move on. :wink:
LATER: I got a subscription. Created my first HTTP request to test and it was almost instantaneous turning off a light even though it all went through the cloud. Neat. Won’t be hard to substitute HTTP requests for some of my Tasker routines that open garage doors, turn on lights, and unlock doors.
By the way, I’ve been using Tasker to react to Pushover events for a while now. Very useful.
I too am lost on this. Could you offer some guidance to us mere mortals?
I’m pretty heads down on migration work at the moment, but if anyone else has figured this out, I would encourage them to share.
Can I be added to the beta group thank you!
Is it possible to check a device’s status using an HTTP request? I’ve looked through the help topic on this and don’t see it. But maybe there’s a way that’s not obvious? I’m starting to move some Tasker routines to SharpTools that relied on the SharpTools plugin and I used the plugin to check the status of devices more often than I thought. I suppose this is probably available from the SmartThings Rules API? I might have to investigate that. But as I said, who has time to completely reconfigure their lives? Ha. Thanks.
EDIT: It’s not the Rules API you mentioned, is it? It was something else where I could use HTTP to query SmartThings? Or maybe not…
I have been down the rabbit hole of the SmartThings Rest API. I have figured out how to get the status and send commands(at a basic level) using tasker and the HTTP Request.
I will share a set of Tasker tasks when I have more time to do the write up on a Get request and Post.
