SuperTile Shows average temps
Is there a way to have a supertile that shows the average temp of all the defined sensors? Like Average temp of the second floor for example?
I’m sure there is probably a better way to avergae temperaturesbut this is how I did it.
I created a variable for eaxh temp sensor and one for the average. Then created the rule as below and added the avg variable to a super tile.
Thank You, I will have to give that a try when I get some time to work on this again
