I am woking on this Supertile -
Which looks like this -
(still needs spacing etc.)
What I want to know is can I add a box in the supertile around the variable result like drawn in with a pen? -
What about uploading a rectangle ‘icon’ and using that to surround your desired items?
Here’s a rounded rectangle ‘icon’ in SVG format that might do the trick…
Edit:
Here’s a few aspect ratios in a more moderate stroke width:
Thanks Josh!
I have no idea why I didn’t think of that…
I can draw exactly what I need and save as .svg
Nice.
One of the things I do for my SuperTiles when I have a number of things that need alignment is actually concatenate various related elements in to a single variable in a Rule then use that variable on the SuperTile. I found that even when I manually got things aligned nicely in the SuperTile editor, it would still be off in some browsers (typically Echo 15 Show renders things a little off). By combining the elements in to one first it’s not an issue.
