Super Tile help
Maybe trying to do the impossible here, but will ask anyway and still early in my journey with SharpTools so may be i am missing something.
Have created a supertile to show the voltage on a Tempest weather station.
It is connected to a top-up charger for when the solar radiation is low and the onboard battery voltage drops to low. This is switched on by a Aeotec smart socket in the garden shed. All works well.
What i want to achieve is a gauge as shown below but with a battery symbol that shows up when is is being charged.
I have created a tile with the Aeotec thing and removed all the data apart from the battery icon, which only shows when is is charging, uses blank icon when not charging.
When i try and place a thing, either as an icon / thing or just a simple thing on a supertile, I can not get the icon to show up as with a normal tile.
Screenshot 2024-10-28 082344
Not a deal breaker if i can not do it, but it would tidy up dashboard and just put a smile on my face !
Andrew
Can you clarify how you are adding it to your Super Tile?
I would normally expect something like:
  1. Edit the Super Tile and tap [Add Item] at the bottom
  2. Expand IconsThing Icon
    a. Select your desired Thing
    b. Select the switch attribute
  3. Select the ? placeholder icon and tap the cog to edit it
  4. Tap the Select Icons button
    a. Add an entry with an icon selection for each state
    • on → Icon
    • off → (blank system icon)
Pay close attention to the capitalization as attribute values are almost always reported as all lowercase.
Works a treat now, i had everything up to the state.
Did not know there were case sensitive, once corrected it works as expected.
Many thanks for the help
Great app you have here !
Andrew
