Super Tile Gauge Units Font changed
Today I made a new super tile gauge and the Units font doesn’t match the super tiles gauges I made a few months ago. Is there a way to change it back to match the older gauges?
Try copying the units from the old one.
Did you perhaps use the combined degree + F symbol from your keyboard or a web search on the newer tiles units? The F in the combined version is probably a fixed style. Whereas using just the degree symbol by itself and adding a separate F character next to it can use the inferred font.
All these Temperature super gauge tiles are using the “Default” units. I corrected the problem by switching the newer gauge units to “Custom” and typing it in. Odd that “default” units font style is different.
Thanks for the update and for sharing your workaround. It’s still likely what I mentioned above but the device is reporting the combined degree F symbol. It’s a special character so it likely has a fixed style (kind of like various other special symbols).
