Sunset trigger seems to be malfunctioning
I have tried deleting the rule and recreating it, but it is still causing errors.
Can you PM me the rule ID so I can take a closer look?
It seems like the rule is fundamentally failing at some point and is rescheduling itself as a reattempt.
I think I just figured it out. I forgot I deleted and recreated one of the virtual switches in the rule and didn’t update the device in the rule after I recreated it.
Yep. It just fired successfully after I updated the device.
Disregard issue.
