The state of my device don’t update anymore. Example, I have a door open but in my dashbord it look closed samething with light open but look to be off on the dashboard. If I turn the light on with the dashbord the command pass and the light turn on and the status on the dashboard is on too. If I switch of dashboard and come back to the dashbord with the light, the light look to be off again bur in reality is on.
Some one can help me with this? Thanks.
I just found in the log this error:
Error sending event to SharpTools.io: status code: 401, reason phrase: Unauthorized
It sounds like the hub doesn’t have a valid authorization token to push event updates to SharpTools.
You can update the authorization token by reauthorizing the hub starting from your SharpTools User Page → Manage Connections
It’s working now!! Thank you Josh for your help
