Starting dashboard in pre-defined Chrome window size
Hi,
this is my first post. I wanted to share the way I found to start my dashboard in Windows using the Chrome browser. Because my dashboard is designed on my cell phone and keeps evolving, I wanted a quick and easy way to display it with the same aspect ratio on my laptop. The following command line does the trick:
Below is a picture of my dashboard:
Great first post! Welcome to the community and thanks for sharing your trick!
That’s a good trick when designing a dashboard on a laptop but to use on the mobile phone (much easier than trying to design on the phone).
Just one thing, you may have to use ‘Program Files x(86)’, depending where Chrome is installed.
