I’ve just bought and installed today a SmartThings hub, could anyone give me any advice on which edge drivers to install which work best with SharpTools, I have already installed v2edge already, thanks
I’m not sure what you’re asking…once you connect SmartThings to SharpTools, you have access to any device (almost) you have connected to your SmartThings.
As said in the other thread, you don’t really need to add Edge drivers.
If your devices are supported and connected to your hub, use whatever it gets. It means when Smartthings changes over, you’re supposed to get stock Edge drivers automatically.
For the devices you can’t get connected, or you feel are missing functionality, you can try and search for a custom driver.
Yep, fully understand now, Thanks
