I don’t have a smarthings hub, all my sonoff devices are linked to the ewelink app, which is then linked to the smarthings app, will this still work when groovy stops?, Thanks
I believe the Sonoff/Ewelink integration is a Cloud-to-Cloud integration which doesn’t use the Groovy platform. If that’s the case, then yes, since you’re already on the next-gen connection it will continue to work when Groovy stops.
Thanks Josh, last question, will virtual Switch, created under the labs tab in smarthings still work with smartthings and Sharp tools, still work when groovy has gone
It’s still an open question over in the SmartThings community. There are community developed Edge Driver equivalents in the event that SmartThings doesn’t provide a migration path for existing Virtual Switches though.
