I’m using 3 virtual switches for SHM on the dashboard. I started looking into Hone assistant and like their version of what looks like a traditional alarm keypad. I’m not sure if this is something that can be done similar in sharp tools?
@Ryan_Mclellan, yes you can created a alarm panel with the style you want in the dashboard. See the post below that @Carlos_Juarez has came out a very decent looking dashboard with the alarm status at top.
He also used the virtual switches that synced with the STHM like you did to show what is the current alarm state. And you can change these STHM switch tiles’ security settings to “PIN Protected” to restrict the access to change the STHM status from the dashboard to mimic the alarm keypad.
