Hi,
I’m running HA in a docker container (Frontend 20230705.0 - latest) on a QNAP NAS and I’ve been using the containerized SharpTools add-on with it for quite some time (sharptools-hass-addon-connector-i386:latest). I had to move the NAS and restarted earlier this week, but I couldn’t authorise the add-on as before. It gets stuck in the second step. After I select the entities it keeps processing, never goes through to the synchronising step:
Everything shows up in the green, but there’s no actual connection. The entities do not update within SharpTools:
I restarted all, several times, but couldn’t get any further. Nothing else changed in the network that I could suspect interfering.
Could you please help, what else could I try? Let me know if you need any further info, diagnostics or anything. Thank you very much in advance!
Kind regards,
Csilla
