SharpTools Bridge private alpha is starting
We’re starting a private alpha for SharpTools Bridge!
SharpTools Bridge runs locally in your home and connects supported local devices and services into SharpTools. The goal is to make more local-first integrations available in your existing SharpTools dashboards and rules while still using the SharpTools cloud experience you already know.
:light_bulb: You must have a device that can run the Bridge software locally such as a NAS, home server, always on Mac/PC, or other machine that stays awake
Early focus areas include:
  • LAN integrations like Philips Hue, Shelly, Kasa/Tapo, Lutron, and Fully Kiosk Browser
  • Matter devices through multi-admin setup
  • Utility devices like calendar event matchers and local HTTP requests
  • Experimental Groovy Labs support for community apps and drivers
Why Private? Can I join?
This first phase is a private alpha so we can ensure a tight feedback loop. Our goal is to validate the overall experience with a small engaged group before expanding more broadly.
If you’re comfortable testing early software and have local devices or integrations you’d like to try with SharpTools, send a PM requesting access.
If you are already part of our Alpha / Beta groups, you can access the private discussion here:
https://community.sharptools.io/t/alpha-local-sharptools-bridge/16473
WOW !….Sharptools really rocks !!.. I would love could connect to Bond Hub, from june to now update status in Bond is not updating correctly in Smartthings for fans. If I set a speed from 1 to 2 b.e bond received adjust the speed correctly, but in smarthings goes back to 1, then there is an inconsistent status, by the second time, setting to 2 again, then Smartthings updates correctly.This mess up all related about speed or ON/Off automations or rules, because now ST (and Sharptools) does not know for sure wich is the correct device status (this is documented in ST forum)…
