Not sure if this is a SharpTools thing but would be good to have the ability for a floating always on top widget similar to what you get with messengers etc on your phone so that some functionality is always available.
The use case for this is for example if your using the Fully Kiosk Browser API to open apps etc but you want to have a floating ‘control’ for something like volume or closing the app or that kind of stuff. Ideally you could drag the floating control around to where you want it.
