Hello. I’m using sharptools on an iPad using a kiosker app. I am currently using Homey pro and have used it with sharptools for a year. I did have a few problems with the status sync on virtual sensors a made using a fibaro smart implant with a physical switch to determine open/closed for my garage door. This did not work well with the sharp tools tile. It was not reliable enough. I figured out that sharp tools worked well enough for simple tiles like light switches and to set scenes for different scenario situations.
Recently i started to migrate to Home assistant to get better control of my devices. I made an ESP32 module to improve the garage control. The device is very simple. An output for opening the garage, and an input to let me know the status.
I started making a dashboard for the garage and started testing it. I still have the same issues like I had on the homey.
Issue with the momentary switch. Instead of working as a momentary switch, it toggles the switch and looses its functionality.
Is this a common issue? Its like as if the sharptools doesn’t synchronize properly. I also had the same issue with my window blinds.
