Hi, I’m really liking the Homey/Sharptools integration so far! However, when I connect Homey and add a Netatmo tile in sharptools, I can only display 1 field (temperature). Is there a way to display multiple data fields from the Netatmo unit within 1 tile, such as CO2 etc?
Looking at one of the Netatmo devices, I can see that it has has all the right data show up in Sharptools, but for some reason the additional values are greyed out. How do I display these?
You can change the tile layout. Some attributes, like battery, have a dedicated tile layout or you can use the Hero Attribute tile layout to display any attribute.
Alternatively, you can use a Super Tile for building custom layouts and mixing and matching data.
Thanks for the reply, Josh! Will look into it. Why aren’t those additional values available for the standard tile per default? It’d be much quicker and more intuitive to have those easily accessible there.
