For starters, I’m new to this so please be gentle. I’ve installed a Konnected V2 conversion kit linked to SmartThings and am trying to create a rule in Sharptools that will delay triggering the alarm to allow entry and exit. I found a previous reference to this topic but didn’t understand the solution. Can anyone help?
Are you using STHM in SmartThings? IIRC, there’s a Delay Before Alert option under STHM, Settings, Security, Response that should do the trick
Thanks for the quick response. I’ve found the setting and will try later. Thanks again
