SetCoolingPoint by minus
I feel silly asking this as I’m sure there’s something basic I’m missing.
I noticed my family saying to Alexa multiple times per day during certain periods, “turn downstairs down” and Alexa will basically lower the current SetCoolingPoint by -2 on our thermostat.
So, I figured I could easily automate that by subtracting 2 from the current cooling point and add to a remote to allow a push of a button controlling it.
Maybe it’s a brain freeze, but I can’t seem to find the current cooling point to do the math to reduce it by some number.
Is this something simple thing I’m missing?
Edit: I’m using SmartThings and am trying to move a thermostat cooling point by -2
What attributes is your device reporting?
Most modern Thermostat implementations on SmartThings separately implement the heating and cooling functions:
  • Thermostat Cooling Setpoint
    coolingSetpoint
    setCoolingSetpoint(value)
  • Thermostat Heating Setpoint
    heatingSetpoint
    setHeatingSetpoint(value)
I can put in a value for SetCoolingPoint but perhaps my issue is that I can’t retrieve the current Cooling Point. I was trying to utilize SetCoolingPoint with math:
IF button presses
SetCoolingPoint to CoolingPoint - 2
However, when I try to grab the current cooling point, it’s not an option:
Interesting. Have you looked at the device details directly from your SharpTools User Page > Location > Thing and does it show the attribute there?
Didn’t think about that, the cooling setpoint value is listed there. Doesn’t that mean it should be accessible via the screenshot above?
Is $AaaTemp a text variable? If so, the list of variable is being filtered to text attributes.
You could create a numeric variable and when you go to set that variable, it should filter to numeric attributes.
And thats it…I knew I was doing something incredibly stupid!
Thanks!
