I am installing a sense Energy Monitor today and was wondering if there is a way to show current consumption on my dashboard? I know it integrates with home assistant, which could then be linked to my hibitat, which could hopefully then display the current consumption on my dashboard. Any help would be appreciated!
@Greg_Shepperd, you should be able to display the energy consumption in the dashboard using the Hero Attribute layout, which allows you to display any attribute(s) in the tile.
Also, in case you are not aware of, SharpTools Home Assistant connection is available in beta, and that means you can bring your Home Assistant entity into SharpTools directly. PM @support if you are interested to join the beta tester program.
Thanks! I’m still waiting to get it installed so I will report back which method worked best
