Hi team,
So I was trying to create a simple scrolling text widget for notifications on the dashboard, can’t seem to get it to fully work. Probably something simple in the code:
<tile>
    <layout>
        <div id="scrollingText" style="overflow: hidden; white-space: nowrap;">
            <span id="textContent" style="display: inline-block; padding-left: 100%; animation: scroll 10s linear infinite;"></span>
        </div>
    </layout>
    <style>
        @keyframes scroll {
            0% { transform: translate(100%, 0); }
            100% { transform: translate(-100%, 0); }
        #scrollingText {
            width: 100%;
            height: 100%;
            font-size: 20px;
            line-height: 50px;
    </style>
    <script src="https://cdn.sharptools.io/js/custom-tiles/0.2.1/stio.js"></script>
    <script>
        // Initialize SharpTools.io Custom Tile library
        const stio = new STIO();
        // Function to set the text content from the notificationText attribute
        function setScrollingText() {
            var thingId = 'lP4Gf14eZidldCMXijb0'; // Replace with your actual Thing ID
            var attribute = 'notificationText';
            // Use SharpTools.io API to get the attribute value
            stio.getAttribute(thingId, attribute)
                .then(data => {
                    document.getElementById('textContent').innerText = data.value;
                .catch(error => console.error('Error fetching attribute:', error));
        // Call the function to set the initial text
        setScrollingText();
        // Optionally, you can add a listener for attribute updates
        // This assumes you have a way to detect attribute changes in your environment
        window.addEventListener('attributeUpdate', function(event) {
            if(event.detail.thingId === 'lP4Gf14eZidldCMXijb0' && event.detail.attribute === 'notificationText') {
                setScrollingText();
    </script>
</tile>
