I ran into something that I thought might be useful for everyone, so thought I would share. I had a hard time finding screensavers that I liked, so I went in search of a solution. I found this gem https://ezgif.com/resize . It allows you to resize any GIF file to the size that you need it. So for example in my case I’m using a Fire 7 and it has a screen resolution of 1024x600. I threw that into the dimensions for the resize and now I have screensavers that are sized for my tablet. If you use Fully Kiosk you can also set a playlist of screensavers to play x amount of seconds before moving on to the next one. This is probably common knowledge but it sure helped me out. Hope someone finds it useful.
