I am new to this and trying to teach myself. This is code I tried posting in a custom tile. But I just keep getting blank screen. Can anybody give me little help. Thanks.
@Dustin_bragg, did you forget to attach the code or screenshot?
Can you paste the text itself?
Once you paste it into your draft, you can highlight the snippet and then tap the </> button in the toolbar so it can be posted.
Edit: I noticed it said scorestream.com in the screenshot, so I signed up for the service to play with. Code below is from the widget I generated from their site.
It looks like it has a fundamental issue for some reason. I’m guessing they probably don’t provide much support for it, but might be worth reaching out to their support.
<div class="scorestream-widget-container" data-ss_widget_type="teamSchedule" data-user-widget-id="48318"></div><script async="async" type="text/javascript" src="https://scorestream.com/apiJsCdn/widgets/embed.js"></script>
It seems like their script wants you to explicitly set the height/width of the box it’s in.
You can add the following to the start of your custom tile and it should fix the issue:
<style>
html,body { height: 100vh; width: 100vw; margin:0;padding:0;}
</style>
So the full snippet in your case would be:
<style>
</style>
<div class="scorestream-widget-container" data-ss_widget_type="teamSchedule" data-user-widget-id="48317"></div><script async="async" type="text/javascript" src="https://scorestream.com/apiJsCdn/widgets/embed.js"></script>
