I’ll add my 2 cents here:
I also have been having delay issues, sometimes up to 5 minutes, (which coincidentally is the default reporting time for the devices).
I got deep into troubleshooting with SmartThings and a few related excerpts follow. Keep in mind that I disabled my SharpTools rules and created duplicate SmartThings Routines because initally they said the issue was with SharpTools.
The information was captured using SmartThings CLI:
Hi Nayely-
I may have captured it.
I ran the CLI and opened the laundry room door a8f50a26-b1aa-40c9-b106-10bfaa483a51 which is in the SmartThings routine “Basement Stairway Lights Turn on”. The lights did not turn on so I left the door open. After about a five minute delay, Basement Stairway Lights e9bf2fde-393e-4f70-9a8f-635466228b13 turned on.
The time was around 7:59 PM or 8:00 PM Eastern Time. Interestingly, the CLI program did not seem to scroll by when this was happening. I looked through the data but could not find a time stamp around the 7:59 PM time. I could just be missing it. I will paste the data at the bottom of this email.
Hi, Kevin.
This is really great evidence, thank you for collecting the info, I already created the report for the engineering team.
In this case, we would need to see why the driver got the event after 5 minutes or so, if it was due to something in the hub, or if the message was actually received until then from the device which I don’t know what can cause it.
Hi Kevin
Nayely will be off for some time, so I am following your case, reading your thread with Nayely I can identify two errors one related to a delay in events and another related to 2 sensors.
1 Case (Events delay): the case is being investigated by the team, as soon as I have updates I will inform you
2 Case (2 sensors): please, Can you explain the issue with these devices? for the last mail, these devices were removed from SmartThings,
Note: if I have missed something please let me know
NOTE: I removed 2 OLD devices that were not being used and replied back to their Engineering with that information.
Hi Kevin
I’m happy to hear that, so I will be pending of the investigation for your first case (Events delay)
DAYS LATER:
Hi Kevin
Unfortunately, we can’t see a delay in the logs in the previous mail you commented that the door was opened around october 4th at 7:59 PM or 8:00, in the locos we can see the following:
1- the device sent the open event to the hub at 2023-10-05T00:05:06.131509479+00:00 UTC
2- the event turns on the light at 2023-10-05T00:05:06.624864145+00:00 UTC
So we can’t see the delay based on the logs, but will still investigate why the device is sending the event 5 minutes after
DAYS LATER:
Hi Kevin
I understand, from our side, we can only discard that as a problem of SmartThings Hub or the Driver, that does not mean that the devices are bad but the reason for the delay is not caused by SmartThings. As you mentioned the problems are generated randomly, in my opinion, something wrong happened between the devices and the hub. they are out of our scope.
I can recommend checking the following :
- Sometimes users have problems with Zigbee and Wi-Fi channels, you can read more here
- Try to re-add the devices on SmartThings
- Check if, after some steps or using a specific scenario, you can reproduce the issue
but there are only recommendations
So basically they gave up at this point!
The delays still persist!!!
ADDITIONALLY: I’ve recently been having unrelated issues with all of my Zooz motion sensors getting STUCK on ACTIVE. They have worked fine for a long time. Working with Zooz Support, I bought a new one and swapped out 1 of them because they initially said the device was bad. Same thing happened. So then I got this reply back from Zooz Support:
Hi Kevin,
We’re currently working with the driver developer and SmartThings support to resolve the problem. It’s not clear what’s causing it other than some type of recent platform change on SmartThings. We’re trying to find the source as quickly as possible and will notify as soon as we have a fix. Thank you for your patience!
Agnes
Zooz Support Team
EDIT:  So now I’m wondering if this “recent platform change” is the cause of these other issues…???
