I created a rule ‘Greenhouse Temperature Check’. It uses variable $greenhouseloop as trigger to check a sensor temperature, and turn on or off based on the state of temperature. This runs every 10 minutes.
This rule engine works for 2 days, and then stopped. I did not make any change.
I check the rule engine and it is enabled. when it works, there is log file. there is no log file.
I restarted Smartthings hub v2.0. I reconnect Smartthings to sharptools.
It sounds like you are using your $greenhouseloop variable as a trigger in your rule and toggling the variable state to try to get it to ‘loop’. Keep in mind that this approach to looping can be finicky and is not something we officially support or recommend.
In general, it’s an anti-pattern to use looping in most cases. Where possible, it’s preferred to useevent driven automations – for example, your greenhouse temperature sensors should automatically report their temperature updates and you should be able to use that for your trigger.
For example, you should setup a rule like:
Trigger: Greenhouse Sensor: temperature changes to greater than 80
Flow: Greenhouse Fan ▸ on()
And if you wanted to combine additional scenarios, you could use multiple triggers and then leverage Context Variables to determine what kind of action to take.
Trigger:
Greenhouse Sensor: temperature changes to less than or equal to 80
Flow:
IF $context.event.value > 80
THEN
ELSE
Greenhouse Fan ▸ off()
That being said, there are some best practices you can follow with the $greenhouseloop approach:
In your case, it seems like you’ve mixed the concept of toggling the ‘loop’ variable with other smart home platform commands – so if any of those smart home platform commands fail, that will cause the rule to fail before it toggles the variable back to true so it won’t loop.
