Super random. I have a home and away switch tied to Smarthings that I use to control thermostat depending on whether we are at the house or not. Recently (last couple of weeks) it seems that this switch is triggering itself at exact hours (1pm, 3pm, 8pm, 10pm) either on or off
. It jumps all over (please see attached screenshot of smarthings showing the events). There are no automations set up at all in smarthings so I am assuming this must be coming from the ST side. Under the ST log for this rule it states âTriggered by device event: Home switch switch is onâ Any clue as to where to start to find out how to fix this. This just started and I have not changed anything in months after I got it all sorted out. Thank you in advance!
Sure please see it attached. In essence when turned on it sets the five thermostat set points. Iâm no expert with rule engines but set it up so that if the thermostats donât respond with the correct temp it cycles back until they are all correct. If there is a better way please let me know thank you!
So 9pm again and the switch is turned on again. No clue where itâs coming from. How is it getting turned on⌠the log doesnât mention whatâs activating itâŚ.
The rule log wonât mention where it was triggered from as it doesnât know where it was triggered from. Only that the value changed and that the rule was triggered because SmartThings reported that the switch changed to âonâ.
In theory, the smart hub would know what triggered the device since it is the origination point of the event. SmartThings previously exposed this information, but based on your screenshots, it doesnât look like they do anymore.
From the SharpTools side of things, you could always disable the rule so it wonât trigger. Of course you would still want to track down whatâs causing that SmartThings device to change, but perhaps that would be a better question for the SmartThings community.
Hi JoshâŚ
Thank you⌠I figured it out, something funky happened on the SmartThings side and a test rule I had from like 2 years ago somehow got enabled again that was causing the issue. Thanks for your time!
