Rule freezes mid-run
Hi all.
My morning routine rule seems to have gone rogue in the last few days.
It starts and then never recovers from the first “Delay” step.
Any Idea what might cause it to abandon, and what a possible fix might be?
Thanks in advance,
Yochai
Hey Yochai,
We looked at the morning run in your screenshot. The rule started on the 05:00 timer, ran the early actions (Mode Home, lights, Sofa, porch shutter), then correctly entered the 1-hour Delay. About 20-25 minutes later the rule was saved/updated in the editor, which clears any pending Delay resumes so the rest of the flow does not continue after the pause. On recent mornings when the rule was left alone during the Delay, those later steps did resume as scheduled.
If you need to change the rule, wait until after the Delay finishes (or split the later part onto a second timer around 06:00) so a Save does not cancel the in-progress pause.
Thanks, Sam, I will verify it next week!
