@josh would it be possible to add a way for the Rule Engine to query the full status of a SmartThings device using SharpTools existing OAuth authorization?
Essentially, I’d like to execute the equivalent of:
GET https://api.smartthings.com/v1/devices/{deviceId}/status
And receive the complete JSON response, including all components, capabilities and attributes, rather than just the individual attributes SharpTools currently exposes.
Ideally, the response could be stored in a SharpTools global variable for further processing or forwarding through an HTTP action.
The goal is to query a device on demand without needing to manage a separate SmartThings API token and the application required to keep it refreshed.
I’ve cut down almost all of my SmartThings usage (projected to be under 1%) by moving most things to Home Assistant. However, there are still some status fields returned by the SmartThings API that aren’t available through local integrations. It appears in the latest blog communication that even using a personal token to access the SmartThings API may be subject to the new developer ‘tax’.
This is really just a nice-to-have, not a necessity. If you see a lot of complications with implementing something like this, I completely understand.
The complexity of the Samsung appliances. There are a lot of ‘supportXX’ arrays that have configuration information that is not available in SharpTool attributes.
Thanks! Can you walk us through one specific end-to-end example? Which device is it, which exact values do you need from the status response, and what would you do with them once you have them (show them somewhere, use them in a rule, send them to Home Assistant)? A concrete example will make it a lot easier to see what you’re trying to do and whether there’s already a way to get there.
Thanks Sam. In this case the only way to get the input settings on Samsung TVs is through the SmartThings API. There are also arrays that hold the configuration of those inputs.
I can get the individual variables with the current capabilities (it’s a little awkward of course) but SharpTools today doesn’t give you access to array attributes or a way to store them. Might be able to stringify them into text.
Here is the YAML I’m using today to do this:
living_room_tv.yaml
rest_command:
living_room_tv_on:
url: !secret living_room_tv_on_url
method: GET
rest:
resource: “https://api.smartthings.com/v1/devices/{deviceId}/status”
method: GET
headers:
Authorization: !secret smartthings_read_only_bearer_token
Accept: “application/json”
scan_interval: 86400
sensor:
name: “Living Room TV SmartThings”
unique_id: living_room_tv_smartthings
value_template: >
{{ value_json.components.main.switch.switch.value | default(‘unknown’) }}
json_attributes_path: “$.components.main”
json_attributes:
samsungvd.mediaInputSource
samsungvd.pictureMode
custom.picturemode
samsungvd.soundMode
custom.soundmode
tvChannel
samsungvd.firmwareVersion
ocf
template:
sensor:
name: “Living Room TV Source”
unique_id: living_room_tv_source
state: >
{% set data = state_attr(
‘sensor.living_room_tv_smartthings’,
‘samsungvd.mediaInputSource’
{% if data and data.inputSource is defined %}
{% set current = data.inputSource.value %}
{% set sources = data.supportedInputSourcesMap.value | default(
{% set match = sources
| selectattr(‘id’, ‘equalto’, current)
| map(attribute=‘name’)
| list %}
{{ match[0] if match else current }}
{% else %}
unknown
{% endif %}
attributes:
switch: >
{% if is_state(‘media_player.living_room_tv’, ‘off’) %}
off
{% elif is_state(‘media_player.living_room_tv’, ‘unavailable’) %}
off
{% elif is_state(‘media_player.living_room_tv’, ‘unknown’) %}
off
{% else %}
on
{% endif %}
volume: >
{% set volume = states(
‘sensor.living_room_soundbar_volume’
) | float(0) %}
{{ (volume * 100) | round(0) | int }}
volume_unit: “%”
mute: >
{% set muted = state_attr(
‘sensor.living_room_soundbar_volume’,
‘is_volume_muted’
{% if muted == true %}
muted
{% else %}
unmuted
{% endif %}
input_source: >
{{ data.inputSource.value
else 'unknown' }}
input_source_name: >
{% set sources = data.supportedInputSourcesMap.value | default([]) %}
| selectattr('id', 'equalto', current)
| map(attribute='name')
| list %}
{% else %}
unknown
{% endif %}
picture_mode: >
{% set samsung = state_attr(
‘samsungvd.pictureMode’
{% set custom = state_attr(
‘custom.picturemode’
{% if samsung and samsung.pictureMode is defined
and samsung.pictureMode.value is not none %}
{{ samsung.pictureMode.value }}
{% elif custom and custom.pictureMode is defined
and custom.pictureMode.value is not none %}
{{ custom.pictureMode.value }}
{% else %}
unknown
{% endif %}
sound_mode: >
‘samsungvd.soundMode’
‘custom.soundmode’
{% if samsung and samsung.soundMode is defined
and samsung.soundMode.value is not none %}
{{ samsung.soundMode.value }}
{% elif custom and custom.soundMode is defined
and custom.soundMode.value is not none %}
{{ custom.soundMode.value }}
{% else %}
unknown
{% endif %}
tv_channel: >
‘tvChannel’
{{ data.tvChannel.value
if data and data.tvChannel is defined
else '' }}
tv_channel_name: >
‘tvChannel’
{{ data.tvChannelName.value
if data and data.tvChannelName is defined
else '' }}
firmware_version: >
‘samsungvd.firmwareVersion’
{{ data.firmwareVersion.value
if data and data.firmwareVersion is defined
else 'unknown' }}
model: >
‘ocf’
{{ data.mnmo.value
if data and data.mnmo is defined
else 'unknown' }}
input_boolean:
living_room_tv_source_refresh:
name: “Living Room TV Source Refresh”
icon: mdi:refresh
automation:
alias: “Living Room TV - Turn On”
mode: restart
triggers:
trigger: samsungtv.turn_on
entity_id: media_player.living_room_tv
actions:
action: rest_command.living_room_tv_on
action: wake_on_lan.send_magic_packet
data:
mac: “28:07:08:9E:AF:42”
delay:
milliseconds: 500
data:
alias: “Living Room TV - Refresh Source”
triggers:
trigger: state
entity_id: input_boolean.living_room_tv_source_refresh
to: “on”
actions:
action: homeassistant.update_entity
target:
entity_id: sensor.living_room_tv_smartthings
action: input_boolean.turn_off
target:
alias: “Living Room TV - Refresh Source on Power or HA Restart”
triggers:
trigger: state
trigger: homeassistant
event: start
actions:
choose:
conditions:
condition: trigger
sequence:
delay: “00:00:05”
conditions:
condition: trigger
sequence:
delay: “00:00:15”
target:
media_player:
platform: universal
name: “Living Room Media”
unique_id: living_room_media
device_class: tv
children:
media_player.living_room_apple_tv
commands:
turn_on:
action: media_player.turn_on
target:
entity_id: media_player.living_room_apple_tv
turn_off:
action: media_player.turn_off
target:
volume_set:
action: media_player.volume_set
target:
entity_id: media_player.living_room_soundbar
data:
volume_level: “{{ volume_level | float }}”
volume_up:
action: media_player.volume_up
target:
volume_down:
action: media_player.volume_down
target:
volume_mute:
action: media_player.volume_mute
target:
data:
is_volume_muted: “{{ is_volume_muted | bool }}”
media_play:
action: media_player.media_play
target:
media_pause:
action: media_player.media_pause
target:
media_stop:
action: media_player.media_stop
target:
media_next_track:
action: media_player.media_next_track
target:
media_previous_track:
action: media_player.media_previous_track
target:
select_source:
action: media_player.select_source
target:
data:
source: “{{ source }}”
play_media:
action: media_player.play_media
target:
data:
media_content_id: “{{ media_content_id }}”
media_content_type: “{{ media_content_type }}”
attributes:
state: media_player.living_room_tv
volume_level: media_player.living_room_soundbar|volume_level
is_volume_muted: media_player.living_room_soundbar|is_volume_muted
source: sensor.living_room_tv_source
source_list: media_player.living_room_apple_tv|source_list
media_title: media_player.living_room_apple_tv|media_title
media_artist: media_player.living_room_apple_tv|media_artist
media_album_name: media_player.living_room_apple_tv|media_album_name
media_duration: media_player.living_room_apple_tv|media_duration
media_position: media_player.living_room_apple_tv|media_position
media_position_updated_at: media_player.living_room_apple_tv|media_position_updated_at
app_id: media_player.living_room_apple_tv|app_id
app_name: media_player.living_room_apple_tv|app_name
browse_media_entity: media_player.living_room_apple_tv
