The rules engine currently allows moving components (device/mode/actions/etc) within the same section. However, there isn’t the capability to move these between different actions.
This can be very frustrating because you may need to move something from the if-block to the else-block or anywhere else in the rule. Today, you need to delete and re-create the component.
See screenshot for what’s possible today (green) vs what could be enabled (red):
