Rule engine -> double pressed button
Hi guys,
How can I set a rule, that is triggered by the double click of the Smartthings button?
The currently available options are held and pushed once. Appreciate the feedback!
Hi @Empire_Home, there is a workaround to create a device handler (DTH) from the official SmartThings one and update one like of the code to allow the attribute to be based on text input, so you can set the rule to be triggered when the button state is double. Please see details in the post below.
