Greetings,
I just set up a SharpTools.io web dashboard for use with Hubitat with the intent of monitoring the temperature of various rooms/sensors around the house. Most of what I’ve done is use existing contact and motion sensors that have a “temperature” attribute, then changing that tile layout to use “Hero Attribute,” then selecting “Temperature” as the primary attribute.
That part was easy.
Now, however, I see some of my sensors have the degree down to the one-hundredth. See screenshot below:
Is there something I can do to round this to the nearest whole number or at least (most?) the nearest tenth? I’m sure that this has something to do with how the sensor itself is reporting this attribute, but (calibration of the sensor aside) this is way more information than I need–so much that it makes it hard to tell at a glance whether some rooms are a similar temperature or not.
If I can already do this, let me know (besides the only/mega-effort workaround I can think of: creating virtual devices in Hubitat for each of these sensors that rounds the actual sensor reading to the precision of my pleasing and using that device here instead). Otherwise, I guess this is a feature request. ![]()
