Hi! With the new Smartthings app update now allowing Ring Doorbell to be added as a device, is it now possible to add Ring Doorbell feed as a tile? What about having the feed open when the doorbell button is pressed?
Hi @Musical_Man , the Ring video feed is unfortunately not open to other integrations at this point.
However, there is a common alternative approach if a Fire tablet is used to host the SharpTools dashboards. You can create a custom Alexa routine to show the Ring Doorbell video when the button pressed or motion detected.
See the post below for more details:
