Hi @Luke_H, welcome to the community. Ring Alarm doesn’t have “public” API, and therefore is not directly supported in SharpTools. However, you may be interested to check out the following workarounds I found from my quick research:
Use the SmartThings community developed Ring Alarm integrator, which requires custom smartapp and device handler, and may be a bit more work to set it up. After setup, you should be able to add the ring alarm device in SharpTools via SmartThings connection.
GitHub - asishrs/smartthings-ringalarmv2: SmartThings Ring Alarm Integration v2 -
Create three Alexa Virtual Switches (SmartThings community developed device) in SmartThings for home, away, and disarm, and use SimpleCommand and Alexa Routine to update Ring Alarm when these Alexa Virtual Switches’ status changes. See the discussion in the SmartThings Community below. And then you can add these Alexa Virtual Switches to SharpTools via SmartThings connection.
Ring Alarm released! (Integration project in post 13) - #215 by Rob_Garcher - Devices & Integrations - SmartThings Community(I didn’t test because I don’t have a Ring Alarm, but from my quick play with the Alexa app, you may be able to do sync Ring Alarm using Alexa Guard, and just update Alexa Guard in the Alexa Routine without SimpleCommand.)
Please note that I am not personally recommend Simply Commands. It’s just something I found from my quick research, and I have not personally used it before. (I actually couldn’t event get my account working at this current point.)
