I am a new user to Sharptools using it with my smartthings hub. I have set up a couple of dashboards and I am finding the following very strange behaviors. It is true for all tiles but I will use an example of a tile that is a light switch with light level.
If I turn the switch on or off with Sharptools it works fine (light goes on or off)
If the light switch is turned on or off any other way (automation, manual switching, smartthings app) it does not update in Sharptools and gets out of sync.
If I change the light level from 25% to 50% in Sharptools, it changes the level on the light BUT DOES NOT record the change in Sharptools.
Does anyone have any idea why I am not getting any updates from smartthings to Sharptools?
