[Resolved] Rule Command Selection Firefox issue
In “Edit Rule”, when I add any device under “Flow”, changing the “Select Command” option doesn’t “stick”. When I UPDATE, the command always goes back to the same thing. This only started happening a week ago - possibly after I changed some names in Smartthings and refreshed the connection.
Any help would be much appreciated as I am completely stuck.
OK, I have been using Firefox to edit Rules. I tried Chrome and everything works as expected. I’ve no idea what it is about Firefox that stops the Rule editing working correctly.
If anyone has any ideas, I would appreciate letting me know as I don’t want to have to fire up Chrome just for SharpTools everytime!
Hi @Colin_Kiddy - I just pushed a hotfix which I believe should resolve this in Firefox. You’ll want to refresh the page while viewing SharpTools to pull in the latest frontend version 260508.1837
Thanks for reporting it and sharing your workaround!
Thank you so much for your timely fix - this works perfectly now in Firefox.
