[Resolved] Modal 'Popup' Dashboards Missing Styles
Hello team!
A short while back (around the time that I believe there was notice about a significant backend change), I noted that any dashboards I have that are displayed as a modal ‘popup’ no longer display any tile colouring. If I attempt to edit the dashboards in question - or navigate to them directly - the styles render as they used to. I’m experiencing the same behaviour on Mac OS, iOS (multiple versions), and Android (multiple versions).
I’ve shared a few screenshots below for reference. Any suggestions? :folded_hands:
Colouring displayed properly when directly navigating to the dashboard’s URL:
Colours disappear when accessing this dashboard by-design, which is via a popup:
Interesting to note that the unfortunate blue island banner is seen here, but is a muted grey when accessing the dashboard directly.
Another instance of colours displaying properly when directly navigating to the dashboard’s URL:
Thanks for reporting the issue! I just pushed a hotfix which should resolve this. Make sure to refresh the page in your browser while viewing SharpTools to bring in the latest updates.
The fix is in frontend version 260407 or newer.
In case your curious about additional details, it looks like the issue was limited to inline styles that were displayed in an overlay dashboard. Normal named styles defined directly in a Theme were not impacted, so it took me a minute to narrow down what the actual issue was. :slight_smile:
You’re a rockstar, Josh! Can’t thank you enough :folded_hands:
