[Resolved] Hubitat Music Cover art stopped displaying a few days ago
Cover art images stopped displaying on Music Player tiles I confirmed that SharpTools is receiving the data—the trackData attribute shows a valid JSON object with an albumArtUrl, and it’s updating. The trackDescription attribute also updates. Although Hubitat updates regularly I don’t see anything there that is causing this - but I could be wrong.
The issue could be that this content is http from the source - Sirius, Spotify, Tunein, etc. As mentioned this was not an issue until recently. Chrome, Safari and Fully Kiosk are no longer displaying.
Interestingly Ferdium which I use to create browser based apps does work still.
@josh Any thoughts? Thanks.
Hi @simon thanks for reporting this. I just pushed out a hotfix which I believe should resolve this issue for you. Can you try refreshing the page in your browser while viewing an impacted dashboard? That should pull in the latest SharpTools updates so you can verify if it’s fixed.
Magic - everything back now. Thanks.
