I installed the Sharptools add on in HA, started it, went to the web ui, authorized, selected some lights in the ‘Authorize Entities’ page, clicked the submit button which chnaged to processing, and it just sits there forever. I’ve left it for half an hour and it’s still processing.
Have tried doing this multiple times and leaving it over an hour once, but it just sits there.
If I select 0 devices/entities etc. to authorize, it does eventually finish and say successful, but it still took over 10 minutes to get to that point.
Sounds like something is definitely not working as expected. Without any devices authorized, the sync should be nearly instantaneous.
Unfortunately, my primary Home Assistant instance bit the dust last night! Let me see if I can get a quick temporary instance back up so I can take a closer look and see if I can reproduce the issue.
Just a quick update that I was able to get a test Home Assistant environment setup, but I was not able to reproduce the issue.
That being said, I pushed out an update that may address the issue based on the error messages I was seeing in the system logs. Can you give it a try again and let me know?
