Good day all. Now that you’ve stopped laughing at the title please read on. I have an old Windows Phone that I setup as my control panel in our guest room. Felt it was a great way to put to use an old device that otherwise would have been sent to the landfill. Anyway, it was working through Thanksgiving weekend and had been since I set it up to do so a couple months earlier. We had guests and they used it to control the lights in the room. However, the other day I went into the room and discovered that the phone was locked up on my sharptools guest room dashboard. I powered off/on only to find that it would not load even the Dashboard selection page. I tried a few things without any luck so I decided to do a factory reset on the phone. Still the Dashboard selection page will no load at all. My hub it the HE fully updated. I know there was an update to Sharptools in the last couple weeks but of course I have no idea if that would have caused the issue. FYI - all other pages at sharptools.io seem to load just fine. On the dashboard page I get the hamburger in the upper left and my profile picture in the upper right. Below that is just a dark grey blank screen. Using the Windows Phone built in IE app. Any thoughts on what might be causing this would be helpful.
Thanks and good day.
