[Resolved] Can not use Timer or Sunrise/Sunset commands
I suddenly can’t create a new rule that uses Timer or Sunrise/Sunset as a trigger.
The system gives the following message:
“No locations has been authorized. Please authorize in user page first.”
Then I go to “Authorize locations” and select “My Home”
Everything here looks OK. But just to be safe, I enter the correct data and save. Tried many times.
But I still can’t use the mentioned commands.
I have just discovered that I cannot change existing rules that contain the commands mentioned.
Thanks for reporting and apologies for the inconvenience! It looks like this was a regression from the recent frontend update.
I pushed an update which should resolve this. You’ll need to refresh the page in your browser while viewing SharpTools to pull in the latest version with the fixes, then the Timer / Sunset trigger cards should work as expected again.
