I have a Hue bulb that’s starting to have a mind of its own. It turns itself on at random times. It becomes active on the dashboard as if it was triggered to do so.
Here’s what I’ve done to conclude that the bulb is the culprit. No other Hue bulbs have ever exhibited this problem:
Rebooted the Hue hub
Rebooted Hubitat hub
Recreated the rules in Hubitat Rule Machine. (They were originally in SharpTools Rule Engine)
Seem to me that the problem has to be with the bulb itself.
My plan:
Remove bulb from Hubitat.
Install new bulb and discover it in Hubitat
Give it the same name as the defective bulb.
Reauthorize devices in Sharptools
Question: Will SharpTools dashboards and Rule Engine now substitute the new bulb for the old one, or will reprogramming be needed?
It will be great if dashboards/rules will have the option to reference devices by name instead of id.
When you have many devices with almost the same number of rules and dashboards quite often one of the devices connection is lost, requiring you to remove/add it and go thru the entire process of amending rules and dashboards.
