Replaced two multisensors…
I replaced 2 Inoveli multisensors with two Zooz multisensors. I deleted the old ones from SmartThings but they still appear in Sharptools. Unfortunately, the new ones do not appear in Sharptools after adding them in the SmartApp. I checked the Groovy IDE and the old sensors are gone and the new ones are there. Suggestions?
Have you moved to the next gen connection? If so, it doesn’t use the Groovy connection at all anymore.
You can proceed through the authorization starting from your SharpTools.io User Page → Manage Connections and when you complete the authorization again it will sync over the devices, adding the new ones and removing the old.
Thank you. You’ve made it very simple!
