Interesting. So when you open the Home Screen shortcut to your dashboard for the first time, it’s still logged in… but only when opening a Hyperlink Tile configured as a Modal it prompts you to log in again?
iOS has some quirky restrictions on apps that are loaded in ‘standalone’ mode (eg. Home Screen shortcut) and I suspect that they are treating the iframe that gets loaded separately from the main app and aren’t saving those credentials.
I’ll test it out and see if I can reproduce. My suspicion is that’s just going to be a limitation of the iOS Safari in Standalone mode and I think the feature request would be to render the linked dashboard directly within the SharpTools app in a modal (more complex) rather than just opening it in an iframe (straightforward).
Periodically a table begins misbehaving. Example: shuts down even though Fully-Kiosk browser is configured to keep screen on. A less frequent experience is for the table to continually reboot.
Often a manual power-off sequence will get things back to normal, but eventually clearing the cache is needed which means login credentials are lost. Fully-Kiosk browser can automatically reload, but Sharptools requires re-submitting credentials. Would be nice if there was a way to login to Sharptools without this step. Windows has this capability.
