I seem to have inadvertently deleted a lengthy rule that’s central to my home displays and automations. Is there a way to recover it?
If you made a copy of the rule, we might be able to restore from that. Or if you reached out to support recently and we needed to snapshot your account for any reason, we might be able to recover a slightly outdated version from that.
Otherwise, no, once a rule is deleted from the system, it’s permanently gone.
I’m out of luck then!
I know how it happened. I don’t normally delete enabled rules. I disable them and then delete the disabled rules days/weeks/months later. This time, when I was cleaning up old disabled rules, I must have deleted this enabled rule too. ![]()
