Any thoughts on how to migrate this garage door controller over from HUBITAT? It runs through and MQTT connection and I would like to add the controller to my dashboard. RATGDO is Rage Against The Garage Door Opener…
Edit: Spelling
Edit: Spelling
If the device is integrated into Hubitat, you should be able to authorize it to SharpTools.
Assuming it implements the related Garage Door capability, it should show up as a Garage Door Tile. If it implements multiple capabilities, you might need to change which layout it uses if the Garage Door layout is not the primary layout.
