I have a 32" 720p tv and raspberry Pi 4 sitting around. Would this work as a decent setup to have an always on dashboard monitor.
As long as you can run a modern web browser, you should be good to go. If you try it out, please do report back with your experience!
How did you plan on interacting with the dashboard since it won’t have a touch screen? Or did you plan on using that device as view only?
Just a viewing only right now.
