Presence based rule before sunset, need suggestions please
I would like to create a rule that will turn on certain lights when my presence changes to present before sunset. I also want one to trigger after sunset, since the lights will be different. Since it’s been a while, is this possible with a rule flow or does it require Life360? Thanks
There are several ways to do this. Since I use Sunrise/Sunset for various things, it makes sense for me to use a variable to help with this…
Create a TRUE/FALSE variable $AfterSunrise
Create 2 rules to set $AfterSunrise
RULE 1:
Trigger – Everyday at Sunrise set variable $AfterSunrise to TRUE
RULE 2:
Trigger – Everyday at Sunset set variable $AfterSunrise to FALSE
Now create your rules that you want to turn on lights:
1-
Trigger – [your presence device] updates
Condition – [your presence device] is present
And
$AfterSunrise is TRUE
Action – turn on [these lights]
2-
And
$AfterSunrise is FALSE
